It's time to revisit and finally complete the audio system, starting with a messy job of properly
installing the front speakers at long last! Typical French - holes everywhere in the door, except
where I need one to be.
Inner skin was cut-out and prepared to take a custom MDF speaker pod. With the pod in place
and firmly attached to the door's inner skin, we treated outer skins, pods and door cards treated
with a couple of coats of bitumen, for at least some vibration damping.
And finally, speaker installed and all the holes sealed. What an unbelievable improvement of
my audio system, quite possibly the biggest single upgrade I've done so far!
Door cards back on, though I did have to remove the lower hole cover I had made, so I will
have to revisit it later and also add LOADS of Dynamat or such material everywhere in the doors.
The next update will be all about audio as well
.Photos here: http://photos.cybernck.com/307breaknck?page=10
